Saving exr from VFB with VRayOptionRE
  • Saving exr from VFB with VRayOptionRE
    How can I do the fallowing:
    load the file into the VFB
    save the exr in the same way VFB saves raw after render is done (vfbcontrol #savemultiimage "C:\path\image.exr" is saving through max's file save) with all the options from VRayOptionRE.
    Marcin Piotrowski
    youtube
    CGI OCIO config 04
    On an empty scene, set the image as an Environment Background (Screen) and render again with the VRayOptionsRE active.
      I was actually hoping for something not requiring rendering. At the moment I'am rendering tiny few fixel region from the actual scene. And I need more than RGB, all the REs.
      Marcin Piotrowski
      youtube
      CGI OCIO config 04
        I guess I'm just looking for VFB's batch image processing with options. The more options the better.
        Marcin Piotrowski
        youtube
        CGI OCIO config 04
          I see. We'll think about it. By the way, which options do you wish to use from the VRayOptionsRE?
            compression (DWA especially. Of course channel content aware - so it leaves all data ones lossless)
            option for saving multi-part exrs.
            Marcin Piotrowski
            youtube
            CGI OCIO config 04
