composite the glare element over 0% opacity
  • composite the glare element over 0% opacity
    Any ideas on how I can composite the glare element over 0% opacity?
    Do you mean you wish to have a transparent background in the element? Usually, you comp it through an addition function (linear dodge, etc.). We do not output a mask, which would have been a solution. Otherwise, what's your use case?
      Thanks.
      I have a scene with objects floating in the sky surrounded by a glare. I have to provide output with the sky 100% transparent. So I need some kind of mask to either knock out the sky and leave the object glare, or a way to composite the glare element over the RGB output (with 100%transparent sky) in After Effects.
        Not sure how you can do it flawlessly without a perfect mask for the lens effects. I've tried some methods, but the results are not great. The Lens Effects work by addition by design. I suppose in your case the Glare should be provided separately.
          Thanks. I'll continue looking and post if I come up with anything.
            Addition is the “correct” approach, but in years past we used to “unmultiply” flares.
            https://www.provideocoalition.com/un...out-a-plug-in/
            It will not be the same as addition, but sometimes is adequate. Those principles can be applied to any compositing app.
              Thanks.
              That looks really useful.
