Is there a way to batch render files in Max 7.5 = Vray that use DR? I just tried and it just seems to error... any thoughts?
Craig
Craig
--Some cut/pasted stuff.. ;) -- Path to save to exportPath = "///aei/Projects/IDD/images/" -- file type renderFileType = ".jpg" renderWidth = 800 renderHeight = 600 renderCamera = $Camera01 -- open a frame buffer for each render (It stays on screen for some reason...) enableVfb = true --seperate so you can adjust the filename in a case statement or a for loop.. whatever RenderFile = (exportPath + "/" + (renderCamera as string) + renderFileType) render camera:renderCamera outputwidth:renderWidth outputheight:renderHeight outputfile:RenderFile vfb:enableVfb
-- Path to save to exportPath = "//aei/Projects/FCCC IDD/images/" -- file type renderFileType = ".jpg" renderWidth = 960 renderHeight = 640 renderCamera = $Camera01 -- open a frame buffer for each render (It stays on screen for some reason...) enableVfb = true fn SetScheme scheme RendScheme:false = ( phaseOne = #($'phase 1 floors', $'phase 1', $'phase 1 floors', $'phase 1 floors', $'phase 1 floors', $'phase 1 floors', $'phase 1 floors', $'phase 1 floors') phaseTwo = phaseOne + #($'phase 2 floors06', $'phase 2', $'phase 2 floors00', $'phase 2 floors01', $'phase 2 floors02', $'phase 2 floors03', $'phase 2 floors04', $'phase 2 floors05', $'phase 2 floors07', $'phase 2 floors08', $'phase 2 floors09', $'phase 2 floors10') mat = sceneMaterials["RoadLayout"] show $'Forest01' case scheme of ( 0: ( --for each different 'scheme' i set a different layout for my forest pro --trees, change the ground map layout of roads and hide/unhide various --building sets.. nothing complicated, but something that can easily get --messy when you need to repeat it in a few weeks for changes eh? $Forest01.splineinc = $treeline_existing mat.diffusemap.filename = "\\\\aei\\Projects\\FCCC IDD\\textures\\Roads_existing.jpg" hide phaseFive unhide $building_driving_range ) 1: ( $Forest01.splineinc = $treeline_phase1 mat.diffusemap.filename = "\\\\aei\\Projects\\FCCC IDD\\textures\\Roads_1.jpg" hide phaseFive unhide phaseOne unhide $building_driving_range ) 2: ( $Forest01.splineinc = $treeline_phase2 mat.diffusemap.filename = "\\\\aei\\Projects\\FCCC IDD\\textures\\Roads_2.jpg" hide phaseFive unhide phaseTwo unhide $building_driving_range ) ) if (RendScheme == true) do ( RenderFile = (exportPath + "/Phase" + (scheme as string) + renderFileType) render camera:renderCamera outputwidth:renderWidth outputheight:renderHeight outputfile:RenderFile vfb:enableVfb ) ) SetScheme 0 RendScheme:true SetScheme 1 RendScheme:true SetScheme 2 RendScheme:true --extent it for about 6 other schemes for the siteplan and you can start to see why setting them all up seperately can get annoying.
