the VFB layer - Background
  • the VFB layer - Background
    does it support alpha channel? I picked a map with alpha , checked 'as foreground' , its seems useless .. it's still all opaque...
    Here it works, I’m on Vray for C4D though. What saving format are you using?
    3D Scenes, Shaders and Courses for V-ray and Corona
    NEW V-Ray 5 Metal Shader Bundle (C4D/Max): https://www.3dtutorialandbeyond.com/...ders-cinema4d/
    @3drenderandbeyond on social media @3DRnB Twitter
      I like to use png format , here's the picture... could you test it ?
ID:	1176756 Click image for larger version
        Back when I try that I’ve used quite a few formats before I was able to get it working, seems to remember I ended up using a 32bit format, tiff or exr.
          The image's alpha should not be premultiplied for this to work. In your case, the fastest way to do it is to load the image in a 3ds Max Native Bitmap, Untick Premultiplied Alpha, and Render Map. Afterward, it should work as you'd expect.
            Great , it works. Thank you .
            I think png may not be a good format for this work..
