vray clouds invisible for camera and refractions
  • vray clouds invisible for camera and refractions
    Hello, I would like to use the vray clouds for scene lighting,reflections and shadows, but for later compositing I would like to keep the background black, this works for vray dome sky, but cannot find same solution for the clouds - is this somehow possible?
    -thanks
    Hi, thanks for posting. Will this work for you?
    Vladimir Krastev | chaos.com
      Hi Vladimir and thanks for the reply, this separates and hide the sky, but I still can see the clouds on the black background. Vray GPU here.
        Hi, you are right with V-Ray GPU the clouds continue to show up over the background with disabled environment map. There is a similar issue logged in our bug tracking system I will add you tread to it and lift it's priority.
          Perfect, thanks!
