I hope someone can help - this is a bit of an epic.
We have recently upgraded to the latest build of Vray (from 1.09r). We have a lot of projects where the buildings are made of profiled metal cladding. Lovely blurry reflections of a HDR image - thats the theory anyway.
I haven't been able to produce a rendered image for the last two weeks because of "Unxpected Exceptions...".
I am trying to render 3960x2770 (which we have been doing for years). I have tried the Vray frame buffer, no buffer, save to vray image format, hyperthreading, 3GB switch, backburner render, local render, DR.....Our machines are dual Xeon 3.06GHz, 2GB RAM, XP SP2 etc.(i.e. pretty good!)
I have tried many many many options: here are my latest:
Here is a screen grab of the image as half of it was being rendered:
Here is a grab of the scene geometry - you can see from the inset it has under 100k polys - not many really:
And here's a shaded view to show the profile - I've put an autosmooth modifier on the editable mesh (all modelling done in AutoCAD):
The other problem is that the renders are taking the best part of a day to get as far as they do, so making 'quick' tests isn't as easy as it sounds. That is essentially what I have been doing for the last two weeks, and my client is losing his patience! I am happy for renders to take a day (that's why we have a renderfarm) so long as they work in the end.
As far as lighting goes, I have one sun casting Vray soft shadows. That and a pale blue environment. The HDR is used only for reflections.
All I get is a 'Unhandled exception....' whenever I use backburner, or a 3dsmax crash when I try locally. At a last attempt, I am *sure* it rendered at 1200 pixels accross (about 45 minutes IIRC), but I have tried so many things I can't remember if the settings were exactly the same.
