VFB Workflow Questions/Clarifications
  • VFB Workflow Questions/Clarifications
    In shifting from Photoshop post-production, to a 100% VFB Back to Beauty workflow, I have some questions that I need to understand better.
    1) If I save a Composite preset, does it contain any changes that I had made in LightMix? In other words, do I need to apply my LightMix preset each time, prior to applying the Composite preset before exporting to .exr?
    2) Are settings that are made in VFB LightMix / Composite "sticky"? For example, if I open a new scene, do the previous settings used become the default for the new scene?
    3) When I apply certain corrections, such as Lens Effects and Sharpen/Blur, I can see those effects visually, but on the .exr, they are not present. Why is this? Shouldn't they be part of the export, just like the Composite is?
    Thanks in advance!
    Dave
    David Anderson
    www.DavidAnderson.tv
    Software:
    Windows 10 Pro
    3ds Max 2024.2.1 Update
    V-Ray GPU 6 Update 2.1
    Hardware:
    Puget Systems
    TRX40 EATX
    AMD Ryzen Threadripper 3970X 32-Core 3.69GHz
    2X NVIDIA GeForce RTX 3090
    128GB RAM
    HI, thanks for posting.
    1 - You can convert your LightMix to Composite and after that it will be in the VFB layer tree pre-set file.
    2 - The settings made in VFB on LIghtMic and Composite are not "stiky", they will reset for each new clean scene.
    3 - If you enable the "create effects result channel" you will have a collapsed image with all effects and corrections
    Vladimir Krastev | chaos.com
      vladimir_krastev Thank you!
      One thing I noticed when converting LightMix to Composite is that you can not have both layers on at the same time (it's VERY blown out). That's why I was thinking that the Composite contains all of the LightMix settings already. Is that not true?
      David Anderson
      Software:
      Windows 10 Pro
      Hardware:
      Puget Systems
      TRX40 EATX
      128GB RAM
        Another question:
        If you have a scene that is rendering and you make changes to VFB (LightMix or Composite) while it's rendering, will those changes be saved when the render completes?
        David Anderson
        Software:
        Windows 10 Pro
        Hardware:
        Puget Systems
        TRX40 EATX
        128GB RAM
          Originally posted by Streetwise View Post
          Another question:
          Yes, they will.
          A.
          www.digitaltwins.be
            I can confirm that nothing above the Composite layer is working in the final .exr Export... I can see it in VFB, but not in the EXR
            David Anderson
            Software:
            Windows 10 Pro
            Hardware:
            Puget Systems
            TRX40 EATX
            128GB RAM
              So the EffectsResult Channel doesn't look like it should?
              A.
              www.digitaltwins.be
                I'm not sure where I find that. Everything looks great in the VFB, but when I open the EXR in Photoshop, none of those effects are there. For instance, I can crank the Sharpen all the way up so it looks horrible, but then in the EXR file, it looks like I didn't do anything. Same with light flare. Nothing. Maybe I'm exporting wrong? I'm using "Save all image channels to a single file" for the EXR. Then from there, generate a TIF and JPG in Photoshop.
                David Anderson
                Software:
                Windows 10 Pro
                Hardware:
                Puget Systems
                TRX40 EATX
                128GB RAM
                  The save option you use is meant for later back-to-beauty, so it would save anything that sits in its own channel (f.e. a glare, or denoise), but will skip anything that's not (f.e. CCs, sharpen, etc.).
                  It's very similar to saving raw, in that it uses our own EXR saver.
                  If you mean to save the *edited* beauty out, use any of the other option (save current channel, f.e.) and save as you please (exr or png makes no difference.). Notice these options use the Max EXR saver (you can tell from the UI).
                  Lele
                  emanuele.lecchi@chaos.com
                  Disclaimer:
