So I don't always have to change things to my settings.
Is there a way to save the VRayPhysicalCamera's default settings to what I most commonly use?
ChatGPT can write Max script, more or less, with some trial and error.
What I do (pre max 2024) is I already have a camera in my template that I just clone when I need, so everything is more or less set up. Normally (from my experience) every camera that you create after, will take those already defined settings or the most recent used settings at least.
Also in Max 2024 you can set defaults now when you right click on any setting in the command panel, so that might be your best bet. https://www.youtube.com/watch?v=mn4N-jDWOH0
