vray_ in materials name - remove - script?
  • vray_ in materials name - remove - script?
    I have searched the forum, but haven't found anything... but maybe I have searched with the wrong search phrase... so don't judge me.
    is there a way to delete the vray_ addition in the material names?
    I have to export many fbx files for importing in cinema and if you convert the model in cinema to corona, then you have funny names in materials... "crn_vray_material_02"
    if I could batch delete the vray_ addition in max it would be great, in cinema there's no way to do that...
    thanks coder for a solution.
    themaxxer
    Pixelschmiede GmbH
    www.pixelschmiede.ch
    Try this:
    Code:
    for m in scenematerials where matchPattern m.name pattern:"*vray_*" == true do (
    newName = replace m.name 4 5 ""
    m.name = newName
    This will remove 5 letters starting from the 4th on materials that contain the "vray_" pattern. If the "vray_" part is located elsewhere in the material name, you should change the "4" (starting index) and "5" (length) values.
    EDIT: Uploading a little script, which can mass edit materials.
      With this you can rename everything. Don’t know if it still works with latest Max-versions.
      :pen: Renaming script for 3ds Max. Contribute to cb109/interactive-universal-renamer development by creating an account on GitHub.
