MultiMatte Renderelement question / Material ID (3dsMax)
  • MultiMatte Renderelement question / Material ID (3dsMax)
    Hello,
    how do I set a material ID?
    I selected a material, then went to Compact Editor, where a field is, but the material is not loaded anymore and not visible.
    How can I load the material from the slate editor into the Compact editor?
    Is the MAT ID also in the Slate Editor?
    2.
    Is it possible to set a multimatte Renderelemenet also by Layer (everything contained in a layer)?
    Thanks
    Found it now in the Slate editor on the top left...
      Originally posted by BeneZ View Post
      2.
      Not directly.
      You can however select all the geo on a given layer and assign it a common Object ID.
      To do so by material ID gets complicated, as one would have to thrawl through the Layer's shaders (potentially including sub-materials.), and then assign IDs.
      Lele
      emanuele.lecchi@chaos.com
      Disclaimer:
