I know there's ScriptSpot, but it seems kinda dead over there (I nevertheless will still try their too) - I'm posting here first because responses tend to be a lot quicker at Chaos
I need a script written (once it has been written it may need tweaking as I progress through my project
Here's the design;
a) I have 100 layer, and in each layer there a varying number of splines between 2 and 10 I'd say).
b) I have a Master_Spline to be used as the master path for sweeping each those splines that are in those 100 Layers.
1) The Script is to go through each of those layers and for each of those splines, create a Sweep Object for it - using the spline as its profile and the Master_Spline as its Path.
2) A Smooth modifier is to be then added after that Sweep modifier.
3) That Swept Object that has just been created is to be placed in the same layer that was being worked through and the name of that swept object is to be a concatenation of the name of the Sweep Profile used along with the Suffix "_Skt".
Note: I want this set up so that if I decide to change the Master Spline after this script has been run, then I'd also want the path of those Swept Objects to also change as well (in other words, of course, I'm wanting Instances here).
And that's it, that's the script I need!
(well, for now
Please can whoever is able to write this let me know how much it'd cost for me to commission them to create it for me?
Many thanks.
PS - To Chaos - I didn't know if this was the best place to put this request, so I hope it's okay to have it here, if it's not, please feel free to move it to the correct one. Thank you
Here's the design;
(well, for now
Many thanks.
