vray nightlies
  • vray nightlies
    afetr installed the vray_adv_61009_max2023_x64_32256, i cannot find the Diffuse path guiding option at Light Cache section
    Jackie Teh
    3ds Max 2023, V-Ray 7 Hotfix 2 [7.00.08 build 00000]
    AMD Ryzen 9 7950X 16-Core Processor@4.50 GHz | 64GB RAM | Nvidia RTX 4090
    Website: https://www.sporadicstudio.com
    Email: info@sporadicstudio.com
    YouTube: https://www.youtube.com/c/SporadicStudio
    That nightly is not available anymore, however, the Path guiding is there in the most recent nightly (3225.
      Hi, which version do you mean? the path guiding you mention here is "Diffuse path guiding option" or the normal path guiding only?
      Jackie Teh
        The label changed because now it does it for speculars and volumes too.
        Lele
        emanuele.lecchi@chaos.com
        Disclaimer:
          Hi, i did not see anything change, here is the printscreen
          Click image for larger version  Name:	image.png Views:	0 Size:	6.8 KB ID:	1190695
          Jackie Teh
            Yes, i didn't recall the "Diffuse" path guiding option you mention either, but assumed you stumbled into some nightly with a misnomered label (as initially it only worked for GI paths.).
            That one you see is the only path guiding option V-Ray has ever had, whatever its name may have been.
            Lele
            Disclaimer:
              It mention in the nightlies release note I install it because of the "diffuse path guiding"
              Code:
              V-Ray for 3ds Max (since 2023-09-05 build/32249 to 2023-09-12 build/32256)
              No relevant changes
              V-Ray for 3ds Max (since 2023-09-04 build/32247 to 2023-09-05 build/32249)
              Modified features:
              (*) V-Ray: Add an option for Diffuse path guiding in the Light Cache rollout; (VMAX-12953)​
              Jackie Teh
                aaaaaah, eheh, that's the mystery explained!
                Confirmed to be the one you screenshot!
                Lele
                Disclaimer:
