sparkles/flakes without changing the base material
  • sparkles/flakes without changing the base material
    Hi everyone,
    trying to add sparkles to a sugar shader.
    I did the sss aspect first, then tried vrayflakes/vrayflakes2/vraystochasticflakes shader to add flakes on top of the sss shader.
    Unfortunately I didn't find a way that didn't involve darkening a lot the base sss material.
    Is there a way to add just the shiny flakes on top of the base material? Should I use a noise mask or similar?
    Hi, thanks for posting.
    Are you using a VRayBlendMtl material?
    Could you send us a screengrab of your material set-up or the scene?
    Vladimir Krastev | chaos.com
      I'm using a vrayblendMTL, yes.
      Will create a scene I can share asap
        Update: on the test scene, everything works perfectly. Blend material, stochasticflakes material masked with a fresnel map.
        I'll try again on the main scene.
