Two-Sided V-Ray Material
  • Two-Sided V-Ray Material
    Is there in issue with two-sided V-Ray materials? I have some plants using them The first slot is the bitmap, the second slot has nothing, and the blend is 50%. The object is rendering either all black, or all white.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Scene/Screencap will be helpful. Otherwise, check the docs.
      In a two sided material, the first slot should be a vraymaterial, not just a bitmap. Not sure how that's even possible. The best way is to enable thin-walled (no refraction > black).
      Set SSS illumination to Uniform, put the translucency map in the SSS color and the SSS amount around 0.3-0.5 depending on the look you're trying to achieve. In the back material you can have a desaturated/brighter and less reflective material with the same settings as previous for SSS.
      A.
      www.digitaltwins.be
