Dirt
  • Dirt
    I have been trying to make a good dirt material for a long time, but nothing I could use. I want dirt streaks, just where you would expect to see dirt. I am working on a stucco house, and I want a subtle streak under my window ledges. Any tips? I watched many videos, but nothing really applicable to a real-world conditions; just boxes on boxes as examples.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Hi, thanks for posting. Here is the docs pages about VRayDirt. I made a test scene for you as well. The most challenging part in my opinion is the bias parameters. You need to set it up with testing for your specific application.
    This is a real-world size window and skirt.
    Please find attached the scene.
    Vladimir Krastev | chaos.com
      Yes, I went through the docs... thank you for the example, I'll see if it works.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        The problem with the dirt thing as a procedural is that it just doesn't look great out of the box, imo.
        It is what it is and you'd need to mix it up to be workable I think.
        For your things Bobby, why not just have a set of decals that you can apply where needed?
        They will probably look better....
          I have done that on a few peojects and it worked well. I saw it as a workaround, but maybe it is a better way, like you said.
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            If the problem is limiting the dirt to only appear beneath the window ledges, try using the z bias to make the dirt go downwards, and then perhaps use a vray distance tex set to target your window geometry as a mask so that you control a bit better where the dirt goes. If you only want the dirt on vertical surfaces, you can use a triplanar map with different colors on the axis so that it does not dirty up horisontal surfaces (as in black and white if the black is dirt and set to multiply for example, you would set the z axis to white so that no dirt appears there). Also i would check out a youtube video by jonas noell on how to create a procedural concrete material, where he has some tricks with using vray colors with different multipliers/rgb output in the vraydirt to make the dirt more apparent.
              Sounds way overly complicated. I had a script that did all this with one click, but the script is no longer around.
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
                There is Rich Dirt of course. I played with it years ago and it might work for you.
                  That is what I was refering too, but it no longer exists and the developer never responds to support. emails.
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                    Weird. The website is still up, with info saying it's updated for Max 24... http://www.enrichpro.com/en/richdirt/index.html
                      The dev is still active and responds to emails. He's keeping it updated.
                        Maybe it is alive again. I'll check it out.
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
                          $249.00 is not realisitc, at least not for me. I think I paid under $50 when I originally purchased it.
                          Bobby Parker
                          phone: 2188206812
                          • Ryzen 9 5900x CPU
                          • ​Windows 11 Pro
                            Email him. If you still have your license info he will work out something with you to update.
                            • #15
                              Yeah, I paid $49 to upgrade to 2019, and the same thing to upgrade to 2020. It is a subscription if you need to upgrade every year.
                              Bobby Parker
                              phone: 2188206812
                              • Ryzen 9 5900x CPU
                              • ​Windows 11 Pro
