Access 6.2 V-ray Lister via hotkey?
  • Access 6.2 V-ray Lister via hotkey?
    Is the only way to access the new unified V-Ray lister via the toolbar button? I can't seem to find it in the list of menu items for the hotkeys.
    Hi, the toolbar is the only way for now. Thank you for your remark. It will be logged into our system.
      Bummer. Hopefully this can be integrated as I really prefer hotkeys to toolbars.
        Hi, you could create a hot key with the newest version V-Ray 6, update2 hotfix 1. You can find more information here.​
          I think this was added in the previous update since I was already using it but I didn't notice that the cosmos browser (and maybe other menu items) is also available as a shortcut in hot fix 1 which is great too. Thanks!
            In 3ds max 2021 I did find it in 6.2.1 but I recently switched to 3ds max 2024 and even though the command is visible in the command list (under an empty category) - the shortcut I applied to it - does not run it. Click image for larger version
Name:	lister shortcut issue.png
            3ds Max 2016/2021 (Vray 6.x), Windows 10 64bit , AMD 2990WX ThreadRipper 32/64 Cores, 128 gigs RAM , 2X RTX3090 48GB RAM
              Try toggling the "keyboard override" button in the main folder and see if it changes anything.
                Ah !
                Thanks !
                That was it.
                Nir
