VRayCompTex
  • VRayCompTex
    In the tutorial "rendering an animation with moving object" it is required to create several VRayCompTex materials and then drag things onto the Source A or Source B bitmap slots. No matter how I shake or dance: I can not drag anything anywhere..... Does someone have the answer to this mystery, or could someone tell me what I am not seeing or doing wrong?
    Thanks in advance.
    souplesse n'oblige
    Right-click on any Material Editor slot, and in the pop-up menu make sure you have the Drag/Copy option checked, and not Drag/Rotate.
      Thanks Vlado, but I checked it out and it was set to Drag/Copy. It still does not work as should (off course there are other ways to create the materials, but it would be ever so handy to just drag and drop).
      souplesse n'oblige
        I think it has to do with how the VRayCompTex material is created. Does one start with a Standard material or a VRay Material? I tried to figure it out on the basis of the comp-tut-comp. max file and notice that the VRayCompTex Mtl is at the very top of the stack, for which I can not see what it originally was...
        souplesse n'oblige
