How to disable "Intensity Rays" in viewport by default when creating lights?
  • How to disable "Intensity Rays" in viewport by default when creating lights?
    Just noticed that after the latest update the intensity rays are enabled in the viewport every time a new light is created (plane/sphere). Is there any way to disable this by default?
    It's really annoying having to turn that off every time a new light is created. Viewport gets really messy when that's on with a lot of lights in scene....
    Hi, thanks for posting. You can use a script to turn off intensity rays. The command for this is
    $.intensityRaysOn = off
    Paste this command in a notepad file and save it as .ms file, for example RaysOff.ms
    Select all the lights you want this checker disabled and paste the RaysOff.ms in your viewport.
    Use the $.intensityRaysOn = on to reverse the process.
    Vladimir Krastev | chaos.com
      well.... that's handy but not exactly what I was looking for.....
      They still show by default whenever a new light is created......
      I don't want them to appear at all
        Agreed. I don't normally need them on and end up shutting them off for 95% of the lights.
          No way to change the default behavior, I'm afraid. Here's a little script to enable/disable the parameter for all VRayLights:
          Code:
          select (for o in $* where classof o == VRayLight collect o)
          for each in selection do
          case each.intensityRaysOn of (
          true: each.intensityRaysOn=false
          false: each.intensityRaysOn=true
          clearSelection()​
          Make a button out of it.
            ok..... until then
              Thank you though... That script assigned to a button does help! Appreciate it!
                Max 2024.2 has an option to define custom defaults:
                Yavor Rubenov
                V-Ray for 3ds Max developer
                  FUCK YAH!!! Yavor for the win!!! Awesome
