Why does VrayDistanceTex affected viewport performance?
  • Why does VrayDistanceTex affected viewport performance?
    Hey everyone,
    can anyone explain why the VrayDistanceTex affects the viewport performance, even when it doesnt show in the viewport?
    Demostrating this on a basic test scene with a default plane and sphere.
    The plane has a VrayMtl and i picked the sphere inside VrayDistanceTex.
    Viewport Shading is set to Standard.
    Test Scene and screenshot in the next post.
    FPS differences when moving the sphere:
    120 FPS (not connected at all):
    90 FPS:
    It even affects the viewport if its not connected to the shader (2.image)
    40 FPS (VrayCompTex):
    7 FPS:
    I´ve attached the demo file as well.
    Thanks!
    ​Screenshot and attached max file:
      No issues on my end. Usually, VRayDistanceTex slowdowns occur when there are many objects in the scene (it assesses all of them), hence why we implemented a "Compute in viewports" checkbox to avoid that. Otherwise, I noticed you were using a very outdated version of V-Ray. Does it happen if you update?
        Thanks for your reply.
        I just tested the file with the newest 3ds max and Vray version. The slowdown still occurred, BUT turning the "Compute in viewport" off and on again fixed it.
        Also I have to admit, I didn´t know there is a "Compute in viewports" checkbox. I only need it at render times so, I can easily turn it off for now.
        Thanks for the help!
