Can you create a render element to mask by layers?
  • Can you create a render element to mask by layers?
    I'm aware that you create a crypotmatte render element to render by layers but from my reading to utilise this in Photoshop you'll have to use 32 bit format. Is there a way to create this with TIFFs at 16 bit?
    So far I haven't had any luck. Is there somthing else I ca use to render masks by layer?
    Thanks.
    And sorry I should say I want to seperate the masks to seperate layers like crypto can
      Ah I just noticed that it saves it in the RGB channels. So maybe I don't need to sperate them all
        PSD Manager is your friend. A mask for every layer.
        Bobby Parker
        www.bobby-parker.com
        e-mail: info@bobby-parker.com
        phone: 2188206812
        My current hardware setup:
        • Ryzen 9 5900x CPU
        • 128gb Vengeance RGB Pro RAM
        • NVIDIA GeForce RTX 4090
        • ​Windows 11 Pro
          Thanks!
          Have you ever used Pulze Post Manager?
            Wrote you a script that will create a mask (MultiMatteElement) for each layer. Try it out.
              Oh amazing!
              Gonna try in out in a while once Iget some work done. Thanks a million and I'll let you know how I get on
                hermit.crab is there any way to choose which layers you want? I'm being greedy now ha
                  I'll see if I can add this feature.
                    Try it out.
                      That's amazing! Works perfectly. Appreciate this.
                        also you can use the exr.io pluigin for photoshop and use the standard cryptomatte.
                        pixel bender @ panoptikon
