walk through tutorial
  • walk through tutorial
    If you were to use Vray lights in the walk-through tutorial that Vlado put together, would you have "store with irradiance map" checked or unchecked?
    Thanks.
    Depends how much time you have
    Unchecked always looks better but can take quite a bit longer to render.
    You can get decent results with it checked if you up the subs to 50 or so
    Eric Boer
    Dev
      Thanks.
      I only ask because I used the tutorial as a guide for a scene I am working on, and when I rendered the final images only some of the lights were on and working - the rest of the scene was dark. I wasn't sure if this was the reason or if there was another reason?
