Changing glossiness in post
  • Changing glossiness in post
    Is this possible and if yes, how?
    Hi, thanks for posting. You can change the amount of reflections in post by using VRayBackToBeauty and compositing but you can't change the actual glossiness parameter of a material. For instance with compositing you can increase the diffuse component and this could look like a less glossy surface.
    Vladimir Krastev | chaos.com
      Ok. Thank you for the fast response.
        You can also sometimes get away with slight blurring of the reflections and speculars in post using a Back to beauty type set up. But truly better adjusting in 3d, as it’s a fake, and generates its own issues, like around edges.
