Bake to texture -VrayExtraTex- Textures just black (Vray6 update 1.2)
  • Bake to texture -VrayExtraTex- Textures just black (Vray6 update 1.2)
    ​Hello,
    I need a projected texture from "Camera Map Per Pixel". Not with any lighting just the texture with a different distortion.
    When I use Bake To Texture I get just a black render.
    When I look at the VrayExtraTex renderelement in the VFB, it is correctly rendered.
    Please help
    - VrayRawDiffuseMap is extremely dark - shouldn't this be just the diffuse input map = Albedo ?
    So there is no Diffuse output.
    (Diffuse Map is in AcesCG and project, too)
Name:	Bake to Texture.jpg
    Click image for larger version  Name:	Baking Progress (V-Ray 6 Update 1.2).jpg Views:	0 Size:	44.2 KB ID:	1215746
    Click image for larger version  Name:	camera map per pixel.jpg Views:	0 Size:	35.5 KB ID:	1215748
    Originally posted by BeneZ View Post
    ​I need a projected texture from "Camera Map Per Pixel". Not with any lighting just the texture with a different distortion.
    When I use Bake To Texture I get just a black render. When I look at the VrayExtraTex renderelement in the VFB, it is correctly rendered.
    Excuse the late reply. Works fine on my end. Judging by the attached screencap, you haven't connected the Camera Map per Pixel to the VRayExtraTexMap's texture slot.
    There's a VRayDiffuseFilterMap. Otherwise, read more about the raw version here.
      Thanks, I found a workaround with RTT, but I will check this when the topic pops up again.
