Sky correction in VFB
  • Sky correction in VFB
    Hi guys! I would like to know if there is a way of correcting the sky (v-ray sky map) in VFB like we do with cryptomate masks for objects. Cryptomate is not working for the sky because its not an object and you can not pick it with the picker. Any chance to correct the sky directly in VFB?
    Thank you
    HI, thanks for posting. This is not available straight away. You have to use VRayBackground render element in Composite mode or Cryptomatte as a workaround. Please read this thread were everything is explained in detail.
    Vladimir Krastev | chaos.com
      What I do is to place VraySky into a Vraydome and with Cryptomatte I can select the environment and adjust the color
Name:	Change Color Sky VFB.gif
      Carlos Rodriguez
      RTstudio
      Tutorials
        Thank you guys! Will try that soon
          It worked. Both methods, although they work in a bit different way and I find the Dome light method to suit me better. Thank you!
