modify automatic file name extensions?
  • modify automatic file name extensions?
    My retoucher has some scripted tools in photoshop. he needs files named in a specific way.
    particularly, having a . in the middle of the filename messes things up.
    is there a way to change the way vray automatically names render elements?
    on a related note, if i choose to save EXR, even doing a still image, it appends a 4 digit frame number to the end (.0000) if i choose png it does not do this. i find no way to change this behaviour.
    edit: the diff in naming between the png and exr is probably due to the fact i saved the pngs manually from the vfb, and the exrs were saved from the "split channels" dialog.. in any case i dont want the .0000.. if im rendering an animation i want _0000.. dots in filenames are not ideal.
    any suggestions?
    https://docs.chaos.com/display/VMAX/...uffer+Settings
    Look on that page and search the page for “dot-delimited”
    I think that just uses nothing rather than a dot.
    Alternately, you could make a script to rename the file. Or the retoucher could fix their script to handle various file names.
    I do agree that the correct delimiter would be an underscore, and the only dot in a file name should be before the extension. Not sure why vray likes dots. Perhaps some special fascination with polka dots, or linonophobia.
      as you suggested, in the end it was easier for the retoucher to modify the script. and yeah, the dot thing bugs me aesthetically if nothing else. .
