Vray Proxy Error
  • Vray Proxy Error
    3DS MAX 2024.2.3 (26.2.2.124)
    Vray 6.2.1
    Forest pack 8.2.6
    Getting this error in deadline render with various VRay proxies. The file is pre-existing and pulled forward from MAX2019/Vray Next.
    Some of the proxies we use were made with much older versions of vray. I cannot tell if something is actually wrong with the proxy files, they render locally and on their own with no issue.
    Which model is reported seems to change depending on what machine renders it.
    These are from 3 different machines however there are many errors of this nature.
    Is there any utility to check vrayproxy files for errors?
    2024/09/30 10:06:48 ERR: [15256] [03696] [V-Ray] [DefMeshFile::getVoxel] 59: Error loading voxel 4 for mesh file "\\mapdrives\maps\images_cd\HQ Plants\hq_palms_1\Alexander palm 03.vrmesh"
    2024/09/30 10:06:48 ERR: [15256] [03696] [V-Ray] [VUtils::MeshVoxel::load] 59: Error loading mesh voxel
    2024/09/30 10:06:48 ERR: [15256] [03696] An unexpected exception has occurred in the network renderer and it is terminating.
    2024/09/30 10:06:38 ERR: [13428] [13076] [V-Ray] [DefMeshFile::getVoxel] 59: Error loading voxel 41 for mesh file "\\mapdrives\Maps\images_cd\Maxtree\Plant Models Vol2\Vray\MT_PM_V2_Gleditsia triacanthos_05_L-MLB.vrmesh"
    2024/09/30 10:06:38 ERR: [13428] [13076] [V-Ray] [VUtils::MeshVoxel::load] 59: Error loading mesh voxel
    2024/09/30 10:06:38 ERR: [13428] [13076] An unexpected exception has occurred in the network renderer and it is terminating.
    2024/09/30 10:05:11 DBG: [08604] [06540] FOREST 8.2.6 NotifyPreRenderFrame
    2024/09/30 10:06:17 ERR: [08604] [06540] [V-Ray] [DefMeshFile::getVoxel] 59: Error loading voxel 40 for mesh file "\\mapdrives\Maps\images_cd\Maxtree\Plant Models Vol7\MT_PM_V7_Mesh_Vray\MT_Plant Models_Vol7\MT_PM_V7_Chamaerops_humilis_02_H-MLB.vrmesh"
    2024/09/30 10:06:17 ERR: [08604] [06540] An unexpected exception has occurred in the network renderer and it is terminating.
    "It's the rebels sir....They're here..."
    To add, these appear to proxies I already remade/updated/
    Some sort of bug or other shenanigans is my guess. Stil trying various things.
      Referencing this existing post. Already UNC, changed forest distribution maps to UNC also see what happens.
      [V-Ray] [DefMeshFile::getVoxel] 59: Error loading voxel 8 for mesh file - Chaos Forums
        HI, thanks for posting. Have you tried to render using Backburner instead of Deadline? Please send us a few of the proxies you are having issues with so we could test them. Please do that here or trough the support contact form. If you choose the contact form, place a link to this thread in the description and the ticket number here in the thread.
        Vladimir Krastev | chaos.com
          Backburner would not be an option at the moment.
          I am bubble sorting the file at the moment, so far disabling displacement seems to remedy the error.
          It may be some memory issue. I did not create this file and it is quite large.
          If I cannot resolve this via further sorting and hunting down possible displacement issue will send to support and see about setting up a backburner server to test against.
            Still no idea what is causing this. MAX24 Vray 6.2.1
            attached are a couple of the proxies that seem to trigger errors in Deadline, there are several and seem to alternate on which cause the error first.
            If it can at least be confirmed nothing is wrong with these then we can concentrate on looking elsewhere.
            https://www.dropbox.com/scl/fi/9bepe...=97r8shy8&dl=0
