Ideas Portal status
  • Ideas Portal status
    Hi, could you explain whats the meaning of the status in Ideas Portal, some are very obvius like Accepted and Declined but what about Pending or Planned I could interpretate that both are the same
    Also it could be helpful that you can share the decision about a Declined Idea, I understand that it could be imposible due to system limitations, but even when having multiple votes some of them are declined.
    Im not an expert in technical info but I always find interesting to read all about it, maibe we can ask for a different solution.
    Carlos Rodriguez
    RTstudio
    Tutorials
    The different status items are outlined here...https://chaoscosmos.ideas.aha.io/sec...55975237780778
      I've also posted this in your idea in the Portal. But Let's have it here as well.
      We could have a different direction for a certain feature, that is already planned and would not correspond with the current wish.
      The idea is not technically feasible.
      The idea lacks a clear explanation of how the feature should function and what it needs to achieve. (In these cases we request more details before canceling the idea. If such are not provided the idea is deleted or declined).
      A status could always change. If an idea was posted for voting, it could still be declined at a later stage. Probably due to technical limitations but not only.
      Thank you for the feedback. We will try to give an answer every time when an idea is declined.​
