3ds Max & V-Ray HDRI Dome Setup
  • 3ds Max & V-Ray HDRI Dome Setup
    Hi all,
    First post on here!
    I am looking to start using a HDRI Dome setup for all renders going forward. The HDRI will be of an internal events hall. I have watched a few tutorials and tried the native V-ray HDRI environment, however, the "grounding" of the floor is an issue.
    In essence, I would like to know the best setup whereby the floor looks correct to the walls and ceiling within the dome, when a camera is placed at any angle.
    Any help would be greatly received.
    Cheers!
    You can check out Jonas Noell's tutorial. He provided some interesting notes about this issue:​
    https://youtu.be/NkfU3Tn-GyI?si=2YrvS8Eopft8z8Y3
    https://youtu.be/VgOaWxAwreA?si=83a-7gNd5Fg7bl1Y
      Thanks for your reply legi008
      I previously stumbled upon Jonas's Advanced tutorial (your second YouTube link), however, I was unable to recreate the results he achieved, by following the tutorial. Even replicating his half dome shape proved impossible for me.
      I am trying to set up a simple scene with a dome HDRI, with the floor showing correctly, simply to use as a consistent backdrop for still renders. I'll also generate 360 views to be used in 3rd party walkthroughs etc.
      My hope is that once I have he simple scene set up correctly, I can use this as a base for any projects and even similar HDRIs.
      Any more advice appreciated. Cheers
        Have you tried using "Finite Dome" in Dome Vray Light?
        Its basically the same thing, this was added in Vray 6
        https://docs.chaos.com/display/CWVRA...ome+light+mode
        Carlos Rodriguez
        RTstudio
        Tutorials
