Select by Material - Broken
  • Select by Material - Broken
    I have been using 3ds max 2025 and V-Ray for my usual texturing and rendering. I downloaded 3ds max 2026 last week. I am facing an issue whereby when I select a material in the material in the material editor, right click, then select by material, nothing is selected.
    I have tried opening other existing models I have produced, that have previously worked fine with this workflow, however when selecting by material, it keeps selecting a single random object that does not have the sampled material applied.
    This is affecting my workflow, as I solely use the select by material to quickly change materials etc.
    Please help, Thanks
    I can confirm this, its happening with Corona too, maibe this is something from 3ds Max but I have seen bugs comming from plugins.
    Carlos Rodriguez
    RTstudio
    Tutorials
      In the meantime Neil FD you could give it a try to this script thatt someone shared to me in "Stack" Facebook Group
      https://www.facebook.com/groups/stac...49006872112461
      Carlos Rodriguez
      RTstudio
      Tutorials
        You could also give it a try to this :
        Windows 11 - RTX 3090 - AMD Ryzen 9 5950X - 128 Go RAM
        Sketchup PRO 25.0.634 + V-Ray 7.00.03
        3DS Max 2025.3 + V-Ray 7.00.08
        3DS Max 2026 + V-Ray 7.00.08
        Chaos Vantage 2.8
        GeForce Studio Ready Driver Version 572.16​
          Happens in Arnold/Scanline, too. It's surely an Autodesk issue.
            Autodesk borking features that have been working for 20 some years again. Standard.
            As not everyone has Facebook I'll also upload the script here. All in all I find this script handier than having to open material edtitor, "get material', select by material, OK. This script is a lot faster and works with multiple objects with different materials.
            A.
            www.digitaltwins.be
