I searched the forum for info, but could not get any results on how to save a VRaymtl in the library. If I try I find it back under 'Incompatible Materials". Any help greatly appreciated!
saving a VRaymtl
wizard, when you load vray there is 2 more options below to use renders for material editos, if you uncheck the lock button then vray will be used for rendering, but in material editor it will be used scanline. You need to make sure both lines say vray as render, and material render.Dmitry Vinnik
Silhouette Images Inc.
ShowReel:
