With frensel checked and unlinked from refraction, can I not have IOR in refraction set to 1,0 and still have reflections? I do not want there to be refraction on the windows (simple plane of glass), this is why IOR is set to 1,0. Though the reflection IOR is set it 1,6. I guess my question is what would be the standard set up for a simple glass window? I do not seem to get reflections, or I get too much without transparency.
Glass and reflections
If you unlink it, you should get reflections. Make sure there is something to reflect in your glass, with planes this can be tricky as they only reflect a small part of the environment.
Yes that is correct.
Normally what we do to get reflections in flat glass is have a big spherical map in the environment slot for all of the objects and then a plane directly opposite the flat reflective surface turned off to gi and camera with the same map as the env so you get generaly reflections from the sphere map and higher detail reflections on the flat areas from the plane.
