DR with Autodesk VIZ
  • DR with Autodesk VIZ
    Hello everybody,
    to use DR with VIZ 2006 I need a new vraydummy.xml that´s OK.
    What gives me hard times is the fact that with the new vraydummy.xml it work only for single frames. Whenever I try render mulitframe animations DR fails at the second and following frames.
    Has anybody made the same experience or a solution for this problem?
    Thank you.
    Greetings.
    Markus
    Current DR does not support animation.
    Eric Boer
    Dev
      do I have to wait for 1.5??
        Yes.
        (But why wouldn't you be Backburning it anyway??)
        sigpic
        J. Scott Smith Visual Designs
        https://jscottsmith.com/
        http://www.linkedin.com/in/jscottsmith
        http://www.facebook.com/jssvisualdesigns
          Backburner with VRAY and VIZ..??
          CCS,
          I have many hours working with different versions of Vray with the different flavors of VIZ (2005-2006). I have a good solid setup across 8 machines and can render out stills with no problem now.
          How do you setup backburner to work with VRAY? I haven't stumbled across that thread anywhere unless I just am searching for the wrong words..?
          Dave
          helpdesk
