Top/Bottom material?
  • Top/Bottom material?
    Just wondering if the standard Max Top/Bottom material is as computationally intensive as the Blend material? I've been using the T/B material for leaves and haven't noticed any render speed difference between using a single material or a T/B. So, I'm guessing the answer is no.
    answered your own question!!
    Chris Jackson
    Shiftmedia
    www.shiftmedia.sydney
      I've been using T/B material on leaves too. I haven't done any comparisons, but I haven't noticed a hit like you get with a blend either.
      sigpic
      J. Scott Smith Visual Designs
      https://jscottsmith.com/
      http://www.linkedin.com/in/jscottsmith
      http://www.facebook.com/jssvisualdesigns
        can you guys post an image up im interested in seeing what your doing with the t/b mat
        Chris Jackson
        Shiftmedia
          top of leaf = leaf top texture bottom of leaf= leaf bottom texture im guessing
            Well... Not that I'm saying this is a great example, but here is one I was playing with.
            Those leaves have no bitmaps. What I was using the top/bottom for was to experiment with a more realistic leaf. If I recall correctly, I had a slight opacity from the bottom side, as well as a lighter color, and a smidge of self-illumination. The tops were a darker more saturated green with a bit of very blurry reflection for a waxy leaf look.
            I liked the direction this was going, but got sidetracked on an actual project. And then I saw that the new vray has a 2 sided material for just such applications (http://www.chaosgroup.com/forum/phpB...ghlight=leaves), so I haven't pursued this method any further.
            (BTW, ignore the render time. I was experimenting with a bunch of different parameters all at the same time.)
            sigpic
              seems to work quite well !!
              I like the result.
                @ CCS
                i like your tree a lot !
                Did you do the geometrie yourself or can you tell me where did you get it from?
                thanks
                Andy
                www.v-cube.de
