Here's my problem: I have control room where I need to place 20 machines. All machines are the same. I made one max file with the maxine, and one file with the control room.
Now I wanna xref the machine scene into the control room. When I use xref scene, I need to do this 20 times, because I cannot instance the xref scene 20 times.
When I use xref objects, I can instance it 20 times easily, but then when I add objects to my machine file, I need to load them into the control room scene etc... and this is a mess and never works well.
So I wanna use xref scene instead of xref object. In fact I'm doing this already, and it works great. But I need to do this 20 times and each time link it to a dmmy to be able to move/rotate it.
How can I instance the machine scene 20 times in my control room file? The machine file is heavy, so I really need instancing and not normal copies.
If I xref scene the machine file 20 times into the control room file, how does vray handle this geometry? Will it load the xref scene 20 times? And how does max handle this? Because my control room file will be unmanagable with 20 copies of the machine scene instead of 20 instances.
So any help on this xref scene matter is greatly appreciated! (and very urgent
thanks,
wouter
thanks,
wouter
