if you look at the buckets done by the host computer you will see its buckets are doing their passes. the rest of the buckets are doing their passes too but all you see on your monitor is the finished pass
Vlado said that that happens because multipass is disabled with DR. You can get the same effect without DR if you uncheck multipass in your IR map settings. Supposedly its faster to leave it turned on, so I do.
