depth of field
  • depth of field
    Where can I find info on depth of field for cameras? I saw nothing in the online documents. I'd like to try it out in some views, but have no idea what the settings mean. Thanks.
    http://www.spot3d.com/vray/help/VRay...ams_camera.htm
    Dan Brew
      Thanks! I must be blind!!
        naahh... your personal DOF settings were just off...
          aahhhh...that's it!
            happens to me too sometimes. i found using a post optical filter on my optic recievers helps. but i had to get the IOR for refraction setup correctly. but i must say that when not using the post optical filters my DOF is very smooth, you dont see any noise in it. wish i knew what sort of samples im using to get it like that.
              what setting do I use to fix my Cataracts?
                dont worry about it....just find a big frickin laser... they all have just one setting....
                  Right, i will pop out after lunch and find one and get to zapping.
                  Thanks for the hot tip...
