I've had other HDRI's (namely Debevec's daylight sequence) do that as well. It appears to be from the probe having too much range, so the samples get to be too varied. I had some success in switching to QMC for my GI calcs, but ultimately what worked best for me was just using a different probe.
Also make sure you are using the right mapping type for the probe. If it's a cylidrical image, you should use HDRIshop to covert it to angular, then use the VRay HDRIMap to bring it into max.
I have the right maping type for the probe. Splutterfish's hdri loader gives much better results although the light is coming from the wrong direction and I can't seem to change it.
"A severed foot would make the ultimate stocking stuffer"
-Mitch Hedberg
I ran into that problem with Debevec's sky probe. I believe it is due to a single, very bright spot (the sun) and too few samples. I got around it by using a smaller, blurred version for my skylight while sticking with the full res version for reflection and background.
-Jeremy
Jeremy Eccles Senior 3D Visualization Specialist
The HNTB Companies 715 Kirk Drive Kansas City, Missouri 64105
For anyone interested I found that the vray hdri loader works with terragen hdris if you use the raw cubic hdri from cube2cross. Before I was converting the cubic hdris to spherical with hdrshop which seems to be the source of the problem.
-Mitch Hedberg
