Vray License (Home + Office)
  • Vray License (Home + Office)
    Some of us take work home weather we like to or not. Does Vray allow for home and office installation since a single license can be used for up to 10 workstations?
    Some confusion there it seems It supports up to 10 DR rendernodes, not 10 installations....But the home/office is usually possible as you will always only use the one or the other :P
    So you can either get the license via VPN, or when the dongles are out via http if i understood that part right.
    Thorsten
      "Soooooon", VRay 1.5 will be released. Then you will have a USB-dongle. This should allow you to work wherever you want as long as you have the dongle with you.
        It was also said the dongle“s lic-server allows grabbing a lic via http...so maybe dont even need to take it home if you got inet
          It would be best to write to vray@chaosgroup.com and explain the situation; typically it is not a problem for us to give you a second license for home use.
            uhm, i tried lately to ask this question, but no answer sniff...
            -- spot | www.nothing.ch
            -- 3d blog: www.onoff.ch
