Hello.
I'm having some troubles with a 8 node renderfarm I built.
I have 8 nodes with xp home and a P4 as fileserver with xp pro plus a workstation where corrently I run the backburn manager and monitor
I can render small scenes with the 8 nodes but as the scenes get a little larger (and the bitmap files they use) I can only render in 3 or 4.
That's strange because the paths are alright, I think the connection limit in xp pro is not reached and the network strafic if not much either!!
3dstudio just blocks in "loading bitmaps" fase with cpu at 0% (the only process at 99% is system idle) and I can't access the fileserver from that node and prety soon all nodes block there.
I notice that after this happens file server shows a lot (10 actually) of connection is the CLOSE_WAIT state even after closing 3dstudio and I need to restart the server connection to access it again or wait a long time...maybe the 240 seconds.
Anyone have any ideia what may be wrong??
Something in network settings or is this some OS issue??
Thanks a lot!
Thanks a lot!
