Distributed rendering has NEVER EVER worked for me, which is really starting to f**k me off - not in almost two years since 1.46 have i ever got a DR render bucket working. I've endlessly trailed through the forum and emailed Chaos, but to no availe.
One thing i'm noticing now, is that when i try and resolve the serves, the wrong IP address is displayed - and it's the same for each server, for instance:
sv001 IP: 217.77.179.100
sv004 IP: 217.77.179.100
etc.
but it should be:
sv001 IP: 10.0.5.4
sv004 IP: 10.0.5.19
etc.
Warning messages are displayed which say:
warning: Render host svse(217.77.179.100) is not responding.
the host computer's name where the license is stored is SVSE, not the servers where vrayspawner60.exe is running.
We have about 16 rendering machines, that are absoluetly fine for backburner - never had any problems. Possible reasons for this to fail i have tried to list below:
1) The Vray License is stored on a work machine running XP Pro, rather than the server running Server 2003 which holds all the maps and rendered frames.
2) The work machine’s license is stored on a D: drive (D:\Program Files\Common Files\ChaosGroup\VRFLServer.ini), not C: where ever other machine has Vray installed to a C: drive.
3) All machine’s are part of one network, but there are different workgroups – some machines are part of a domain, other’s aren’t. – this difference in workgroups wasn’t seen to be an issue as all machines will render properly through backburner (16 machines) and all machines can access each other through the network.
4) All 3dsMax.ini files on all computers are exactly the same, except the .ini file stored on the work machine which hold’s the license, where all C: extensions are replaced with D: extensions.
5) We have no internal firewalls, there are no permissions to stop anything through the network.
All servers with the Vrayspawner60.exe file will start, and Max will sit minimised in the taskbar. If I enter the I.P address to find the server – 10.0.5.19, then this address is resolved, but DR doesn’t work. I get the warning message:
warning: Render host svse(10.0.5.4) is not responding
Again, this is the wrong computer name for that IP address.
Anyone? Please - i will love you forever.....
etc.
but it should be:
sv001 IP: 10.0.5.4
sv004 IP: 10.0.5.19
etc.
