Just installed Viz2007...MAPS!!!!!
  • Just installed Viz2007...MAPS!!!!!
    I just installed Viz2007 and the maps are not working. I am using 1.47.0380. Is this the correct version to use ? I thought I read here that it was. Any help needed badly.
    Thanks,
    Mike
    http://mikebracken.cgsociety.org/gallery/
    It seems that only the maps in the default directory are missing during render. Very strange.
    edit: actually, all maps seem to do this sometimes.
      is it that the Viz06 problem continues into Viz07?
      i better stick with Viz05 as long as i can, or go straight for Max!!
      DON'T LET SCHOOL INTERFERE WITH YOUR EDUCATION / www.ds4arch.com /
        I also cant get the spawner to open on the other machines.
        I created a directory called "network"...still no luck.
          i think you have to uninstall backburner3 and install burner2.XX that come with viz2006, to make DR work , about the textures issue is like i said in other post , i only have problems in the first day i install viz2007.
            Have you tried using standard materials instead of vray materials?
              Standard mats work fine. But I must use Vray mats.
              Ill try the backburner thing. I open the spawner and within 1 second its gone. I have to get this DR going.
              Thanks for the replies.
                To get DR working, you can see this topic:
                http://www.chaosgroup.com/forum/phpB...dummy60#114236
                ALso, I believe someone mentioned that there is no Network folder in the root folder of Autodesk VIZ 2007 by default, so you'll need to create it.
                  Thanks Vlado ! I dont know how I missed that thread.
                  Your quick responce is again appreciated. Chaosgroup certainly
                  provides the best customer service in the business.
                  Regards,
                  Mike
                    Still no luck.
                      Originally posted by mmikee
                      Still no luck.
                      Ok, so the spawner still cannot get VIZ stable and running? If you look at the VIZ log file, does it say anything useful?
                        did you create the network folder in all server“s??
                          Maybe it can be the same problem as with spawner running with 3ds max 8. Instalation of previous version of backburner solved the problem.
                          http://www.chaosgroup.com/forum/phpB...ic.php?t=14493
                          The jujubee's comment. Can be something like that.
                            Hi again. My spawner log gave this error.
                            ========================== Starting new session ==========================
                            1: Got this module name: C:\Program Files\Autodesk\VIZ2007\vrayspawner60.exe
                            2: Got this INI file name: C:\Program Files\Autodesk\VIZ2007\VRaySpawner.ini
                            3: Reading settings from INI file: "C:\Program Files\Autodesk\VIZ2007\VRaySpawner.ini"
                            4: [2006/Mar/29|10:26:32] --
                            5: [2006/Mar/29|10:26:32] Dumping current settings...
                            6: [2006/Mar/29|10:26:32] VRaySpawner temp dir: ""
                            7: [2006/Mar/29|10:26:32] Application name (MAX/VIZ): "<VIZ root folder>\3dsviz.exe"
                            8: [2006/Mar/29|10:26:32] --
                            9: [2006/Mar/29|10:26:32] Process id is 2360 (0x93
                            10: [2006/Mar/29|10:26:32] *** ALERT! Error opening file "<VIZ root folder>\vraydummy60.xml" for reading
                            11: [2006/Mar/29|10:26:32] Exiting our service due to errors
                            12: [2006/Mar/29|10:26:32] ========================== Ending session ==========================
                            And nothing in the viz log.
                            I did creat a folder on all machines called "network". I also created the ini file as described by Vlado. I even tried uninstalling backburner 3 and reinstalling backburner 2.
                            I basicaly tried everything that I read in the different threads here.
                            Thanks for taking the time to help, everyone.
                            Regards,
                            Mike
                            Edit: Unlike the max8 errors, The spawner here never opens and never tries to re open. I can see it in my system tray for mabey 1/2 a second, then it is gone and the log reads as above.
                            • #15
                              Here is the vizlog......
                              2006/04/29 10:11:13 INF: [2006/Apr/29|10:11:13] ================================================== ==========
                              2006/04/29 10:11:13 INF: [2006/Apr/29|10:11:13] Console created, VRay Adv 1.47.03 from May 16 2005, 17:16:41
                              2006/04/29 10:11:13 INF: [2006/Apr/29|10:11:13] Compiled with Intel C++ compiler, version 7.1
                              2006/04/29 10:11:13 INF: [2006/Apr/29|10:11:13] Host is 3dsVIZ, version 8
                              2006/04/29 10:11:13 INF: Loaded C:\Program Files\backburner 2\Network\ServerJob\vraydummy60.max
                              2006/04/29 10:11:13 DBG: [2006/Apr/29|10:11:13] [VRender] Constructor entered (loading from file).
                              2006/04/29 10:11:14 INF: [2006/Apr/29|10:11:13] VRay DLL version is 1.47.03
                              2006/04/29 10:11:14 DBG: [2006/Apr/29|10:11:14] Setting default filter kernel.
                              2006/04/29 10:11:14 DBG: [2006/Apr/29|10:11:14] [VRender] Constructor done.
                              2006/04/29 10:11:14 DBG: [2006/Apr/29|10:11:14] Loading from file.
                              2006/04/29 10:11:14 DBG: [2006/Apr/29|10:11:14] Loading filter parameters.
                              2006/04/29 10:11:14 DBG: [2006/Apr/29|10:11:14] Loading done.
                              2006/04/29 10:11:14 INF: Job: C:\Program Files\backburner 2\Network\ServerJob\vraydummy60.max
                              2006/04/29 10:11:14 INF: Starting network rendering
                              2006/04/29 10:11:24 INF: VIZ is ready to begin render
                              2006/04/29 10:12:22 DBG: Starting network
                              2006/04/29 10:12:22 ERR: comsrv
                              2006/04/29 10:12:33 INF: [2006/Apr/29|10:12:33] ================================================== ==========
                              2006/04/29 10:12:33 INF: [2006/Apr/29|10:12:33] Console created, VRay Adv 1.47.03 from May 16 2005, 17:16:41
                              2006/04/29 10:12:33 INF: [2006/Apr/29|10:12:33] Compiled with Intel C++ compiler, version 7.1
                              2006/04/29 10:12:33 INF: [2006/Apr/29|10:12:33] Host is 3dsVIZ, version 8
                              2006/04/29 10:12:33 INF: Loaded C:\Program Files\backburner 2\Network\ServerJob\vraydummy60.max
                              2006/04/29 10:12:33 DBG: [2006/Apr/29|10:12:33] [VRender] Constructor entered (loading from file).
                              2006/04/29 10:12:33 INF: [2006/Apr/29|10:12:33] VRay DLL version is 1.47.03
                              2006/04/29 10:12:33 DBG: [2006/Apr/29|10:12:33] Setting default filter kernel.
                              2006/04/29 10:12:33 DBG: [2006/Apr/29|10:12:33] [VRender] Constructor done.
                              2006/04/29 10:12:33 DBG: [2006/Apr/29|10:12:33] Loading from file.
                              2006/04/29 10:12:33 DBG: [2006/Apr/29|10:12:33] Loading filter parameters.
                              2006/04/29 10:12:33 DBG: [2006/Apr/29|10:12:33] Loading done.
                              2006/04/29 10:12:33 INF: Job: C:\Program Files\backburner 2\Network\ServerJob\vraydummy60.max
                              2006/04/29 10:12:33 INF: Starting network rendering
                              2006/04/29 10:12:43 INF: VIZ is ready to begin render
