Motion Blur and Digital Fusion
  • Motion Blur and Digital Fusion
    Hi all -
    I've seen a lot of threads about MB and how to save to a RPF file, and use that file in Combustion to create the MB effect -
    But does anyone know the workflow in Digital Fusion?
    I can't find anything in the help files, tutorials, or anything on the web --
    Thanks,
    DZL
    Nope, afaik.
    Definitely not as a filter (has a DoF blur, though.) under "rich pixel"
    You could try split the velocity pass(rendered separately) in its RGB components, and use those as multipliers for a conditionate directional blur, however that's done in Fusion.
    Overcomplex...
    Lele
      So, what do you suggest? Motion Blur in Vray takes for-freagin-ever...
      Or, should I just attempt this in combustion??
        in combustion is one filter.
        and no passes, just a channell to tick.
        worth trying it out with the demo at least
        Lele
          yeah, i just downloaded the combustion demo to try it out -
          pretty simple stuff...
          Thanks, studioDIM
            Try lowering your subdivisions to 4 instead of 6. Also, you can probably raise your adaptive sampling (global QMC) a bit since everything is going to be blurry anyway.
            -=GB=-
            Galen Beals
            Animator/Technical Director
            Portland, Oregon
              What about Aftereffects. Can it be done and whats the procedure.
              www.VisualizationStudio.com
                Twixtor!
                Needs more cowbell
                  in other programs it can be done through reel smart motion blur (plugin) if thats so, from vray you need to export motion vector as a special pass, which will contrain rgb information, that will go to reel smart and produce blur.
                  Dmitry Vinnik
                  Silhouette Images Inc.
                  ShowReel:
                    http://www.revisionfx.com/mblurversion.html#DF
                      Where is rpf motion blur in After Effects?
                      My Youtube VFX Channel - http://www.youtube.com/panthon
                      Sonata in motion - My first VFX short film made with VRAY. http://vimeo.com/1645673
                      Sunset Day - My upcoming VFX short: http://www.vimeo.com/2578420
                        oh boy.
                        The third thread in the space of two weeks on this...and the infos are simply doubled and trebled.
                        Making it sticky in the off-topic or something?
                        Lele
