IRR
  • IRR
    What's the difference between 'Add to current map' and Incremental add to current map' ?
    http://www.spot3d.com/vray/help/VRay...vancedimap.htm
    cheers,
    Lele
      Yeah, read that, but supposing I've rendered and saved an IRR map and then need to add or take-away some geometry and need to re-render that bit only, which do I use? (Static scene, 1 camera)
        Thats not quite what its meant for. For a start you cant take away from the map. So once the GI is calced you can only add to it.
        I would use incremental add in your adding in some geometry.
