VRay Sky
  • VRay Sky
    is there a possibility to turn the Vray Sky at 180 degree?
    Jonas
    www.jonas-balzer.de
    www.shack.de
    well map it to a vray dome light.
    Marc Lorenz
    ___ ___ ___ ___ ___ ___ ___ ___ ___ ___ ___ ___
    www.marclorenz.com
    www.facebook.com/marclorenzvisualization
      It's been some time since i last visit this forum... how do i use a VRay sky. do we have it in 1.47.3?
      sigpic
        nope. you dont have it.
        as for turning it 180 degrees.....why?
          For the same reason you would rotate a hdri or any other texture I suppose?
            to create a feeling of vertigo?
              well if you want to rotate it around the z axis...then you just have to rotate your sun node. If you mean rotating it around x or y then i assume you cant.
              Only mehtod i'd have in mind would be rendering a spherical HDRI and using the map :P
              Thorsten
                rotate the sky 180deg
                Probabaly easier to turn your camera upside down and then rotate your geometry.. hahaha
                  I have to create a kind of under/Overwaterworld
                  and it would be very nice to use the Vray Sky for illumination/Background,
                  but turned.
                  to turn the sun doesn't help, even not to use it in domelight.
                  Daforce: haha thats a great idea
                  best regards
                  jonas
                  Jonas
                  www.jonas-balzer.de
                  www.shack.de
                    definitely render an HDR panorama and stick it as a BG then.
                    Lele
