Locked up rendernode
  • Locked up rendernode
    I've got a rendernode here that won't process any scenes throug back burner or DR.
    When I try to send anything to it, the processors sit at 25% and nothing gets processed.
    I've tried rebooting, resetting BB server.
    Has anyone else experienced this with BB?
    Bret
    mabe its somthing to do with the bb patch that autodesk produced not long ago?
    http://www.3dvision.co.il
      was that included in one of the service packs for max 8?
      We have several nodes all set up the same way, this one machine is the only one we have this problem with.
      Bret
        yeap , its backburner 3.0.2 instead of the 3.0.0
        check on autodesk site
          i would suggest to delete the files contrained in the 3dsmax/network folder which relate to vray dr and try agian.
          Dmitry Vinnik
          Silhouette Images Inc.
          ShowReel:
            OK, still not working.
            I tried deleting and replacing the vraydummy60 MAX and XML files(located under max8/network). I replaced them with the files located under the max root dir.
            Uninstalling and reinstalling BB (both for max 8 and max7)
            rebooted and it still hangs.
            The bad node launches maxand loads the scene. It hangs while displaying Building Lightcache under the rendering window.
            It seems as though its able to connect, but not render the scene.
            could there be something else I'm overlooking here? There are no maps or IES files in the scene that need to be loaded over the network.
            Bret
              What are the specs of the master and slave? Also are both installs exactly the same, same plugins? same ini's same plugin versions?
              Eric Boer
              Dev
                Just tried a different scene. its back to hanging at 25% CPU
                Master Specs
                opteron 265 4gig of ram Max 8 Vray 1.47.03 (win XP)
                Slave Specs
                dual opteron 270 4 gig ram Max8 Vray 1.47.03 (win XP 64 bit)
                All pugins are the same, Vray,simian etc... the test scene I'm using souldn't be using any plugins other than Vray.
                As for the .ini there is alot of stuff in there ......the directories at the bottom are different because the program locations are slightly different. But this shouldn't affect the the file being loaded right? What should I be looking at there?
                Bret
                  I would suggest you make all your machines use the same version of vray. You never know....
                    TYPO
                    They're all using 1.47.03.
                    I don't know what else I can do for the Max-Vray setup.
                    I'm beginning to wonder if its a network issue.
                    Has anyone had problems with windows server licences? We currently have two or three more machines than licences, but our IT guy seems to think there is a little leeway there,
                    We have win64 installed on the slaves, and 32 bit on the master, but I've read here that people are using the two together all the time with no problem.
                    Bret
                      Bret,
                      Have you tried rendering a scene with Max scanline renderer and BBurner?
                      Craig
                        Just tested a scanline rendering and its hanging on that also.
                        Bret
                          As a follow up. I had to uninstall BB and Max 8, plugins and reinstall.
                          Now its working fine.
                          Bret
