to produce a mirror material wouldnt you just set the reflection amount to pure white? im getting a perfectly black plane. any help would be greatly appreciated.
mirror ????? possibly stupid question
does the mirror has something to reflect ? if you just put a plane in your scene and apply a mirror material and leave everything then it will render black because of the black enviroment you got. throw in a couple of objects or an enviroment map to see if that helps. btw, i uploaded some of the vray shaders i collected over the past years in this forum or at evermotion.org. the matlib also contains a mirror material (which is actually quite simple) but will only work in max8, if you are intrested then go and grab them at www.olli96.net.
Olli
