Vray light material - multiplier?
  • Vray light material - multiplier?
    This may have been asked before but either the search engine is not optimal or I'm just no good at using it, which is why I have to ask. (again?)
    What value does the multiplier of the light material represent? Is it in watts as with the vray light, normalise on/off?
    I have to do some (fairly realistic) studies/representations of 25 watts LEDs in action.
    thanks in advance..
    cheers,
    K.
    If you have the lumens for the self-illuminating object (e.g. 1700 lm for a 100-watt bulb) you need to divide this by the surface area in meters (use the Measure utility for this), and you'll get the multiplier for the material.
      alright, thank you very much..
      cheers,
      Karsten
        If I am using Feet and inches (system unit = 1inch) do I need to convert the surface area to square meters in the calculation?
        thanks
          thanks
          yes.
          nikki Candelero
          .:: FREE Your MINDs, LIVE Your IDEAS ::.
            candles
            Thanks Nikki,
            I made candle flames that are about .002 sq meters which, unintentionally, calced out to be about 1 candella/mult of 40. of course!
              looks pretty good
                I dont know if this is in the manual. but it should be there...
                -Tom
