This post isn't specific to VRay, but this forum generally seems the most helpful, so I hope no-one minds me posting it here.
Basically, I've got a building that I've modelled in NURBS in Rhino, and imported into Max using Powertranslators.
I need to map some circular images on to the ceiling, so that they follow the contours of the surface, as if they were big circular bits of wallpaper.
On the whole, this seems to be working, except in one place where two surfaces meet, and I need to have half a circle on each.
I'm getting the following result:
I think one half is fine, but I think the other should be doing this (red line):
It's important that I get this as accurate as possible, which it obviously isn't at the moment. And I don't want to have to warp the images to compensate for the mistakes with the mapping.
Has anyone got any reccomendations as to how to get a bit closer to the desired result? I've been stuck with this for quite a while now, and don't have very much longer to sort it out. Any help would be much appreciated.
Here's a better picture of the ceiling in case it's hard to get an idea of the shape from the images above:
Cheers,
John
Cheers,
John
