IR for a simple pan
  • IR for a simple pan
    I have a camera setup to render 300 frames very slow. Couldnt I render
    LC as fly through + render IR map at the starting frame, ending frame, and a couple in between using incramental add to current map and still have a good IR map for the 300 frames? Kind of like the box camera for
    pans.
    Regards,
    Mike
    http://mikebracken.cgsociety.org/gallery/
    Yep, that should work
    You probably don't need to use the LC in fly through though, unless you are using it for glossy reflections.
    Eric Boer
    Dev
      Is this a *true* pan? If so, skip the ani. Render one giant image and do it in post.
      sigpic
      J. Scott Smith Visual Designs
      https://jscottsmith.com/
      http://www.linkedin.com/in/jscottsmith
      http://www.facebook.com/jssvisualdesigns
        SO the LC will work saved from just a couple of frames throughout the animation ? If so, that is a real time saver.
        Thanks for the tips
        CCS, How would you do that ? Pan the image ? Interesting.
        Regards,
        Mike
          for a simple pan, just render a highres still and animate the zoom/position in post. Even if you have a couple foreground objects, they can be blocked out in post as well to complete the illusion.
            actually on a true pan you wouldnt even notice any paralax effects on forground objects. only on a camera move would you see it
