one of the persistent problems that i can't seem to figure out with vray is how to eliminate blotchiness in ambient shadows. i just saw some beautiful renders on here this morning, so others have figured it out. could anyone give me some tips on settings that will help to get rid of this problem.
in these images below, i'm noticing a lot of blotchiness where the metal glazing frame meets the ceiling. for some reason, i'm also getting some blotches on the wood wall, even though it is receiving direct light.
here are some of the specs from my scene:
- i rendered the irradiance map at high quality; global subdivs set to 4; my light cache was set to 800 in 4 passes.
- most of the GI is coming from environment light and a direct light (sunlight); the cove lighting is generated from a light material
is it possible that geometry could be causing the problem? all the modeling was done in max so it is clean.
as much as i am loving vray, i have yet to produce a final render that i am totally satisfied with. if i could figure out the blotchy areas that would take me much further.
thanks in advance for any suggestions!
OVERALL SCENE
BLOTCHY AREAS AROUND FRAME
BLOTCHY PATCHES ON WOOD
OVERALL SCENE
